I am trying to rewire our bedroom so that a switch that currently turns on/off a receptacle will instead control a ceiling fan and leave the receptacle always hot.
Receptacle: Has 3 cables coming into the box. The outlet has a 1 hot wire and 2 neutrals attached to it. In the box there are 2 hot and 1 neutral wire nutted together.
Switch: Has a 2 conductor cable coming into the box.
I have installed the fan in the ceiling and have run a cable in the attic from the fan to the switch box. At this point I am confused as to complete the wiring of the switch and the receptacle. Any help would be greatly appreciated. Thanks.
