My bedroom is a bit cool so I started using an electric space heater (that doesn't have a fan). I noticed it makes the air very dry. What's the best way of counteracting this? I was thinking of putting a bowl of water beside it, using a humidifier or using a fan. Would any of these help?
EDIT: I should ask, are humidifiers safe? I've got wood furniture and a computer in the room and was wondering if they would grow mold or damage electronics? If they are safe to use, should I put it right beside the heater? Should it be a warm mist or cool mist?
UPDATE: it appears the heater blows cold air, and it shouldn't be doing this.
A humidifier is made for this exact purpose.
However
I personally do not care for any form of a humidifier, and I tend to like my environment on the drier side (<30% humidity).
Only by using a humidity, and some common sense can you monitor the actual moisture content of the room. Most humidifiers belong to two groups, heat and ultrasonic. The first group simply heats water from a resevoir and allows the steam/vapor to enter the room. The second uses ultrasonic motion to disturb the water from the liquid into the atmosphere, without greatly affecting the temperature.
Most of these are meant to be temporary and mostly intended for those ill with respiratory infections or similar (unless they are part of a central heat/air system).
A better solution would be to identify the reason your room is cold, rather than run a space heater. These are notorious for causing fires, drying out the air, etc.
Any time the humidity starts to creep above 50% and/or a mist/vapor is deposited/concentrated there is a chance for mold/mildew.
Electronics generally do not like any form of moisture, but again, so long as you keep the humidity under 50% and prevent any misting or precipitation, there should not be any issues.
Prior to getting a humidifier or putting out a bowl of water anywhere, I would purchase an inexpensive humidistat to try and figure out what the moisture level is. Watch it for a day or so, then decide how to proceed.
Also, please be safe with your space heater. Many a desk, office and home have been lost to these things.
| improve this answer | |
  • Are those safe to use with electronics in the room? Do they cause mold? – Celeritas Sep 1 '15 at 19:23
    @Celeritas Updated answer for you – BrownRedHawk Sep 1 '15 at 19:45
  • @Celeritas I've checked out some of your other questions and posts about mold, air conditioning, etc. Are you still in the same garage apartment? If so, it seems like you may want to sit down with your landlord and request/suggest some improvements. You definitely appear to have some circulation, heating and cooling issues. – BrownRedHawk Sep 1 '15 at 19:48
  • Nope. New place! Also I was just about to ask a question about a drafty window but noticed there already are some. Hopefully when I fix that I won't need the heater. – Celeritas Sep 1 '15 at 19:51
    Like a digital thermometer, it could be keeping a history of readings. – BrownRedHawk Sep 13 '15 at 18:49
Get a meter that measures the relative humidity. Don't just go by what it feels like. If you do add a humidifier, don't go over 50%. Otherwise, things could start to mildew.
  • Do you have a recommendation for a good humidity meter or are they all pretty much the same? – Celeritas Sep 13 '15 at 2:09
  • I would read reviews on amazon and similar. Buy the best rated one you can deem reasonably priced. – BrownRedHawk Sep 13 '15 at 12:26
