I'm about to replace the original 1950s era back door on my house with a pre-hung. I'm planning this as a DIY job and have watch plenty of videos, but one thing that hasn't been well addressed is what to do with the original threshold. I have added a couple of pictures. I imagine i have to rip it (the green piece) out, as it is sloped, and then replace with a level piece and put my new door frame on top of that. Am I on the right track? Any further advice specific to the threshold aspect of this job? Thank you.
You will find when you remove the old jamb that the green sill is attached to the jamb. The natural wood part is the threshold, that will pop off in a few seconds, it is only held in place with a few nails. Of all the old door jambs I have pulled, the jamb is long enough to attach to the ends of the sill. That is what is helping keep it stable. There is a possible chance that it still may be stable if you take a multimaster to sever the jamb from the sill, but I would not hold my breath. You could use a reciprocating saw for this, but it may scratch up other things you don't want damaged. Because you have the issue of the sloped sill, I would not keep it in place.
Whenever I address an old jamb such as this, I remove it all, threshold too. The trim should be pulled anyway on both sides. Once that is done the shims holding the jamb should be evident. This is also where the nails are that hold the jamb. Cut them all with a reciprocating saw, or just hack out the jamb anyway you can. You can almost use reckless abandon for this part, but don't go too crazy.
If you didn't go too crazy the green sill should be salvageable if you choose to save a few bucks. Whichever way you choose, either a new sill or reuse the existing, the sill will need a level place created on it for the new threshold to set. This is why I remove it. A table saw is needed for this or perhaps a band saw will suffice. The important thing is, that when the flat, level spot is made, it is 3/4" below the finished floor. You will need the extra room by doing this so you do not need to cut the header. This also keeps the new threshold from getting too high, they are normally 1 3/4" tall. Setting it in the floor 3/4" will leave the bottom of the door off the floor 1" so area rugs or cocoa mats will not be dragged by the door. If you are lucky the finish floor goes under the threshold a bit so it can be cut to a clean line almost flush with the finish wall, NOT the base. This is where the new threshold will meet this cut. OR if there is a gap there at the place where the old floor meets the new sill, a small shoe can be added, but I try not to do this, just my preference.
Back at the cut of the sill. The slope of the sill and the cut needed to make a level spot will most likely take a cut wider than a table saw can handle, but I also have an electric planer to finish and fine tune the flat spot. A band saw would do the cut in one pass.
I have a nasty sketch below to illustrate what I have done in the past.
Then again, this what I get into, you may not find this small detail that critical, and it may work for you simply putting it in flat all the way through. The important thing is, lower it enough to get it under the header, also so it isn't so tall, but high enough so it does open over a throw rug, carpet or cocoa mat.
@ojait, Thanks. I use Paint, the drawing program that comes with MS Windows. It is a basic no frills program, but it gets it done. Trimble Sketchup does a great job too.– JackCommented Sep 1, 2015 at 15:24
Most if not all doors available today are sold at a 6' 8" standard height. There are several widths to choose from. The new pre-hung replacement door should have a slanted sill attached to it's jambs. So, when you are ready to remove the old door: remove old door from entry (remove the pins or unscrew the hinges), remove exterior trim from top and sides. (This will expose the edge of the doors jamb). The easiest way to remove the jamb is with a saber-saw and cut the fasteners securing the side and head pieces from wall (check for electric runs and water lines). The jamb will tilt out in one piece if cut all the nails. You now have a hole in your wall, but technically is labeled a "rough opening". Take measurements side to side and from the bottom of the header to the sub-floor and decide on the door size.
Your new prehung door should come with a threshold. So, if the heights work out right, you'll remove the old threshold and drop everything new into place.
However, if you have to do surgery on your door, height-wise, it might be better to cut off the new threshold, cut the bottoms of the jambs, and cut the bottom of the door.
If you post back with the height of the existing opening ("rough opening", measured from subfloor to bottom of header which is revealed when you pull off the interior trim) and the height of the new door, we might be able to offer more advice.
Thank you all for your quick help and the education on the sill versus the threshold. I really found the diagram very helpful and it addressed exactly the part of the job that I needed help with. It also prompted me to buy a table saw (any excuse)! The wife will be thrilled, but hopefully she'll like the new door. Cheers.– ds007Commented Sep 2, 2015 at 21:09
