I have a Tri-State home with a center beam extending from one gable end of the house to the other at the peak. The beam is completely exposed in the living room. I installed a ceiling fan with light twenty years ago and now the unit has failed. I need to install a new one. I have surface mount wall switch and conduit going up to the beam where the old fan was. I have no electrical box, the wires were enclosed in the canopy of the fan unit. Is this okay to do. I installed this myself twenty years ago and the guy from the building center where I purchased everything said that was okay. I am now having my doubts. What should I do?
Stop being a cheapskate and get a box, will ya?
What you need is a surface-mounted ceiling fan box, either of the saddle or the pancake types. Wiring a fan without a box is a great way to drop a ceiling fan on the head of an unsuspecting guest, as well as a fire hazard if a splice ever fails! Just make sure the box you get is rated for the fan load you have...
No pancake boxes! Those things don't always meet box fill requirements, and may or may not be rated to support the weight of a ceiling fan. The catalog (PDF)(page 8) lists that pancake box at 35 lbs fan weight, and 50 lbs fixture weight. – Tester101 Sep 1 '15 at 1:24
@Tester101 yeah, whatever box he gets needs to be rated to handle the weight of the fan. – ThreePhaseEel Sep 1 '15 at 1:34
@Tester101 -- also, does wiring space provided by a fixture count towards box fill space? – ThreePhaseEel Sep 1 '15 at 1:35
If the volume is marked on the canopy, then it can be used (314.16(A)). However, I doubt you'll find a canopy with a volume marked on it. – Tester101 Sep 1 '15 at 1:48
@Tester101 -- that's odd that they don't, I suppose -- penny-pinchers at work? – ThreePhaseEel Sep 1 '15 at 3:33
