I live in a multi apartment building. All the neighbors has AC.
Many AC's has condensation drainage pipes which descent into the common garden and are cut at about two meters above ground. Others are cut at much higher heights.
I want to extend those low hanging pipes to funnel the water to the trees we have in the garden.
There are two types of pipes. I have attached pictures of both. The pipes are cut in a rough way, no connectors at their ends.
My questions are,
How can I extend those pipes? What kind of connectors should I be looking in the store?
Can I extend it into a drip irrigation system? Is it possible without adding pressure?
