One of my A/C units was struggling to keep the temp. down to 85 three weeks ago. The pipe outside was slightly frosted so I already knew the unit was a little low of refrigerant. Called repair company to check unit out. The service technician said the unit was 2 lbs. low on refrigerant. After three more days of the unit struggling, I called for them to please check the unit again for me. Two different technicians happened to be sent out. At this time, there was no sings of any frost on the pipes. The techs told my wife that the unit has a leak and we would need to replace the unit if it continued not cooling properly. The techs also said they put an additional 3 lbs. of refrigerant in the system. They also quoted us total replacement for $5,892.00. They put in an order for a new unit.
This did not make any since to me. Next, I started monitoring the thermostat. every time the thermostat showed the unit was cooling it down a little I would lower the temp setting. Instantly the current temp. reading on the thermostat would go up a degree. Well, I put two additional temp. readers next to the thermostat and both of them said the current temp was 4 degrees lower than the thermostat.
So, I decided a new thermostat only cost around $38.00 and I replaced it. To my surprise, the unit started cooling immediately and has been for the last 20 days. I would bet that the on the second service call, the unit did not need or take anymore refrigerant. I did call the company and told them the unit started working so they could cancel the new unit ordered. I failed to mention to them that I put a new thermostat on which fixed it.
So, is there a tester for thermostats? I have never seen one tested.
