I have a well with a 30/55 pressure switch, and I hate the shower pressure. I am redoing the main water appliances with a new pressure tank (going from 20 gallon to 35 gallon), new 40/60 pressure switch, a sediment filter, whole house filter and water softener.
Each appliance uses a 1" hookup and I'm worried about the flow. Should I use 1" PEX equivalent to 3/4 copper or go with 1" CPVC? I'm worried about all these appliances obstructing the flow.
From my well I have a pressure tank, then a sediment filter, then a whole house Morten filter, than a water softener.....with these appliances I don't want to lose flow....each has a 1" hookup on it and feed in is a 3/4 " copper......should I go with cpvc in between 1" or Pex 1"
