Do I have to put the 120 volt wiring in my attic inside of conduit? I don't recall ever seeing any wiring inside of conduit in an attic but I'm not sure.
  • Try searching the site for questions dealing with wiring in attics, you should find quite a bit of useful information.
    – Tester101
    Aug 23 '15 at 21:29
  • I appreciate everyone's patience with me being new to this site and your input has been most helpful!
    – user41750
    Aug 24 '15 at 2:15
  • I still have not had the time to merge my accounts but if I access the site through the app which I downloaded to my phone and use that route to use this site then it shouldn't be any problem hopefully
    – user41750
    Aug 24 '15 at 2:16
No, conduit is NOT required in attics. Not unless conduit is required in your area.
There are other factors involved in wiring in attic spaces, but your question is a bit too vague to go into that.
  • Speedy Petey - thank you very much for your comment I'm just running a ceiling fan to each of the 3 bedrooms and the living room as there is no overhead lighting installed in the house they have two open spots on the breaker panel he wants me to use one to wire all four of the fans just wanted to make sure I did not need to put the wiring going through the attic in conduit I suppose I'm going to run it right across the bottom of the rafters
    – user41750
    Aug 23 '15 at 15:17
You only have to put the wiring in conduit, if you have to protect it from physical damage. i.e. If you're pulling individual wires, or cables are run in such a way that protection is required.
Without knowing what type of cable/wire you're installing, it's difficult to be more specific.
    Or if you live in Chicago...;-)
    – Kris
    Aug 23 '15 at 21:26
