My electric dryer will run but wont heat. I'm not very good at electrical work, so I've spent a lot of time researching and did some testing last night.
My High-Level thermostat basically fell apart in my hand with the slightest touch. My Thermal cut-off also seemed to be tripped (reading open with my Ohm meter). I checked the lint in my vent piping and it didn't seem bad, so that was a little concerning because I figure these parts wouldn't just fail without a reason.
So I also checked my element, wondering if maybe that was burned out as well. The reading I got on it was 4 ohms. The things that I read vary wildly, but most of them say look for a 10 ohm reading. I removed the element and inspected it and there are no cracks or breaks visible in the coil. What does 4 Ohms tell me? Do you think my element is OK, or should I replace that too?
Basically I don't want to replace the high-limit thermostat and the thermal cut off only to have them blow again right away because the element is the culprit.
