I am roughing in some plugs in my kitchen for when the workers come and hang the cabinets. I am getting cabinets with LV lights on the underside of them. The cabinet makers asked me to make sure I have my boxes out 5/8" past the drywall.
I am just wondering how I should go about this, since I am not sure how the workers hang the cabinets over top of my electrical boxes. Sticking the boxes out past my wood frame (5/8" + 1/2" for drywall) is quite far past the wood frame. Meaning I wouldn't be able to secure the box very well since the mounting holes for the box only go back about half the boxes depth.
I am using BX on wood frame (half the kitchen is steel studs and half is wood so I must use BX because some wires go between the steel studs and wood).
I can see two options. Perhaps there are better ones. My preferred method would be to use a 4x4 metal box, with a 1/2" mud ring. I understand how the drywallers go around a mud ring with a router, and it works great for them. Than I was wanted to wait till the cabinets were mounted and add a box extension for the 5/8". I am just unsure how the cabinet team will cut out my electrical box. Do they use a router? Or do they notch it out with a jigsaw based off where they measure it will be in there cabinet? I just don't want to leave them a rounded mud ring if they actually just need a squared off electrical box....
I could also get 1 1/8" mud rings I believe but they would be special order so I prefer not to.
Therefore the big question is, How do they cut out electrical outlets when hanging cabinets?
Thanks for your help.
