The attached picture is a bathroom floor. The tile worked loose and on lifting it I found extensive black mould under it (killed and cleaned off it before the picture was taken with a mould killer product). The surface under the tiles looks like a thin layer of plywood. The very dark coloured patches in the picture have completely disintegrated to a rotten mush and have clearly been wet for a significant period of time.
To the right of the picture is a shower cubicle which previously leaked (small sealant failure AND a small grout crack) - these leaks have both been fixed. It is likely the source of new moisture has now been stopped.
I believe what has happened is the shower leaked under the tiles, and over time the boarding has rotted in some small places, which has allowed tile movement that has then led to grout failure and a loose tile. It's only at that point I found the mould.
As I see it I have three options:
  1. Make best attempts to kill the mould (which is almost certainly under the adjacent tiles), dry the area as much as possible, remove and fill the small rotten areas visible, and refit the tile. Downside: Mould may continue to exist and still find a route to emit spores into the living spaces.
  2. Lift all the adjacent floor tiles (and further if necessary), remove all the damaged boarding, dry the area out and kill any mould, fit new boarding, reinstall the tiles. Downside: Tiles may break when lifted and I have NO spare tiles and probably cannot buy matching.
  3. Rip the whole floor out and fit new board and new tiles. Downside: Cost, risks of damage to other tiles areas, and extends the area to be re-tiled as ALL tiles of that type need replacing whether affected or not.
The room is on the upper floor of a house (1st floor to us Brits, 2nd floor to my American friends). The floor construction is wooden timbers (likely immediately under the sheet boarding that has rotten) which are left-to-right in the picture, so would probably support movement of water to the affected location. The bathroom is fairly well ventilated with a constantly running humidity sensing fan.
What would you do?
Floor
Sorry to say this, but number 3 really is your only option. First the reasons why:
  1. I can tell just by looking and from your description, your subfloor is rotten and now unstable. More tiles and grout are going to crack, come up.
  2. The mould is almost certainly inside the sub-floor and maybe even the jousts. Cleaning the surface will very likely not do much of anything except stir up mould spores into your house. Don't reuse stuff that has mould on it. Throw it away (including the tiles).
A few things to keep in mind: You cannot with 100% certainty identify what type of mould it is just by looking at it. It might be worth your time to have a sample tested. The mitigation methods for certain types of mould are much more stringent. However, you could just assume it's the worst case and mitigate it that way. In any case, you're going to want to have your house tested once all mould is removed and BEFORE putting new coverings or sub-floor back in. That's just one of the steps. Do some research on how to mitigate. It's not a simple process and it's not to be taken lightly.
Potential health problems from mould exposure can be much worse than many other things including asbestos. You'll want to do some research on how to mitigate this. Things like respirators are an absolute must regardless of the type of mould and full hazmat gear may be required recommended. You'll likely need to seal off the location and provide negative air flow to the outside. You'll likely need some air-scrubbing filters.
Sorry for the bad news, but mould is bad business. It's very likely already causing health issues that you may / may not be aware of as yet especially now that you've tried to surface-clean your sub-floor and stir up the spores. Regardless of whatever product you're using advertises, they don't always work. Do your research with this one, don't just buy a product / clean it and hope it's good to go.
    Additionally, I wouldn't keep any porous materials that may keep those spores and continue releasing. This generally means ALL of the building materials. I would check, as since it is mold, at least a portion may be covered in your homeowner's insurance! Aug 17, 2015 at 19:11
  • Thanks for the detailed response. As I was writing the question I started to conclude that this is a much more serious issue than one tile, and have to accept that this needs properly rectifying and will cost some money to sort out.
    – Ollie C
    Aug 18, 2015 at 7:49
  • It sucks I know... I literally just did this on a walk-in shower in my current residence which was built in 1962. When I pushed on the tiles in the shower, they would move. Looked like for years someone had tried to re-seal them over and over again. Sure enough, there was mould all the way to the studs and floor joists. All had to come out. Masks, hazmat, the whole bit. I saved the studs by cleaning and scrubbing with bleach (mould was only barely on surface) and had to shave one of the joists down about 1/4 inch and shim it. Feels good to have all that out of the house though.
    – maplemale
    Aug 18, 2015 at 15:45
  • I might add... we were having reoccurring respiratory issues for a year or more after moving in. Getting every cold that came along, usually one every other month. And when we went on vacation we felt so much better, we thought it was radon, and so we abated that as well. But, that didn't really solve anything. It was the mould all a long, hidden in that bathroom out of sight.
    – maplemale
    Aug 18, 2015 at 15:46
