What underlayment should I use for 3/8" engineered flooring stapled to plywood subfloor?
3Check the manufacturer's installation instructions. – Tester101 Aug 12 '15 at 17:29
For nail down, no underlay is needed. But for install and to help reduce noise from the wood floor rubbing against the subfloor (when someone walks on it), use red rosin paper.
