I am trying to stick a strip of LED lights under a bed base (which is covered with a bed base kind of sheet). The adhesive behind the LED strip has worn off. I have tried to get some cloth tape and wrapped it around trying to use it as a double sided tape which didnt work. Then I tried to just tape the LED to the bed base at equal spaces, which didnt work either. The tape just kept coming off after sometime.
All indoor/outdoor double sided hanging tapes specifically say not to use on porous material.
So how can I stick plastic on to cloth ?
