I'm currently renting a unit in a commercial warehouse complex. Each unit has individual MLO panels inside the unit, and then a large split meter base with individual breakers for each unit in a centralized location in a separate part of the complex.
We're trying to upgrade the that main breaker for our unit from 100A to 125A if we have to, but preferably 150A.
So the problem we're having is that the breaker in the centralized area is a Cutler Hammer QC2100, and is part of their QuickLag series, which only seems to go up to 100A. It's a cable in/cable out breaker and it connects to https://www.platt.com/platt-electric-supply/Circuit-Breakers-Cable-In-Out-Base-Mounting-Clips/Eaton/QC6BP/product.aspx?zpid=61066 instead of something like a DIN rail or a simple bolt on. The clips are attached to the enclosure, and the breakers for everyone else's units are just kinda in a row on their own separate set of clips.
Does anyone know if there's a similar style of breaker that will fit on those clips and has a higher ampacity rating? Can I remove the clips and switch to a bolt on style breaker, or install a short DIN rail and attach to that? I'm trying to avoid having to change out the entire meetering enclosure cause I'd be paying to modify 16 other tenants systems and that gets a little pricy.
my electrician and several supply houses in the area don't seem to know if there's a way to do it without upgrading the service for the entire complex, so I figured I'd ask here.
Thanks in advance.
