I'm trying to find studs along my wall and have been successful except for the wall corners which have me confused. I am using a magnet to find the studs which is working well. However, along the wall corners in my house the magnet attaches to the wall along the entire vertical length. It seems like there is a metal plate in these areas. I am not knowledgeable with construction and am wondering - is it safe to use the wall corners as studs? If so, do I need a particular type of drill bit to get through this? Do people generally stay away from these "wall plates"?
Thanks in advance for the help.
