My outdoor faucet is leaking. I was trying to remove the handle so I could replace the washers. I could not get the screw to budge. Now I have stripped the stuck screw. What do I do?
  • Is the screw head flush with the handle or is it round and sticking up from the handle?
    – bib
    Jul 25, 2015 at 16:54
  • It is round and flush with the handle. Jul 26, 2015 at 10:28
You could drill a small hole straight into the screw from above and use a screw extractor (or "ez-out"), it can be a difficult operation with varying degrees of success depending on experience and skill.
Or you could break off the handle, you could then get a grip on the protruding screw with pliers to remove it. The problem is you may or may not be able to procure a replacement handle.
You should probably start looking at replacing the entire faucet just in case your efforts to remove the screw are unsuccessful.
  • +1 to replacement. Get a nice ball valve hose bib and avoid washers for the foreseeable future.
    – User95050
    Jul 25, 2015 at 20:48
