My unit is on the ground floor, I am thinking to combine kitchen and living room to create an open kitchen and renovate original kitchen to a bathroom/Laundry. I know it sounds crazy and probably insanely costly, just curious if it is possible? In terms of plumbing/electrical works, what should I do to make sure it is doable?
Below is the floor plan:
Floor plan
    What is underneath your unit? It seems that all of your plumbing is on the bottom wall. It would be heavily dependent on the amount of access you have.
    – DMoore
    Jul 21 '15 at 5:04
  • 1. Floor plan not attached (I can't see anything below Your last line ("Below is the floor plan:"). 2. It may be wise to post country Your unit is located, as codes may differ between countries. 3. I believe that it may be doable, details will matter here. Jul 21 '15 at 9:10
