I have the a wiring situation similar to below but also have a red power wire coming in from the ceiling. I have 2 wall switches, 1 for fan and 1 for light. How do I include the red power wire coming in?
Are you installing the exact same device as picture (Hunter Universal Fan & Light Remote Control #27185), or some other device? If it's a different device, please include the brand & model number. – mjohns Jul 20 '15 at 18:22
Exact same device, just have an additional red power wire coming in. – R3A Jul 20 '15 at 18:29
I've updated my answer. – Tester101 Jul 21 '15 at 10:14
It sounds like you are converting from a fan that did not have a remote control to one that does.
In many older fan/light setups, power came to the wall switch with just two wires, hot (black) and neutral (white). There usually was also a ground wire, most commonly bare, but sometimes green. In many cases the incoming hot line was connected to two switches, one to control the fan and one to control the lights. The cable from the switches to the ceiling usually had three wires (plus a ground). The neutral wire was for both the fan and light, but the hot lines were separate. They are most often black and red. There is no firm rule as to which goes to which.
In the ceiling box, the white wire was connected to the white wires from the light and the fan. The hot wires are separately connected to the hot from the fan and the hot from the light. Those hot wires may be the same or different colors, usually black, red and sometimes blue (or even a striped color).
In modern fans with remote controls, the whole fan/light assembly is often set up with no wall switch. In those cases, you follow the diagram in your question using just a black (hot) and a white (neutral), plus a ground going to the remote controller in the fan unit itself. On, off, and level control for the fan and light are all controlled from the remote. If you want this setup, you can remove the switches, and in the box that held the switches, connect the black wire bringing power to the switch directly to the black wire going to the ceiling fan unit. Leave the red wire that was attached to the second switch unconnected, cap it with a wire nut, and put a blank cover over the old switch box.
You can also leave a wall switch in the mix. In that case, the wall switch is a master - when it is off, everything is off. When it is on, you then can control the various features with the remote, even turning everything off. But you only need one switch. Either remove the second switch and use a cover plate that has one side blank, or leave the second switch unconnected but in there filling the hole.
If you plan to use the remote, you can skip the red wire in the ceiling, just cap it off with a wire nut. If you want direct control of the light and fan from the wall switches, you can usually skip the controller unit in the fan unit, but you lose control of speed and light level.
SUPPLEMENT
Based on further feedback from the OP, connect the black wire in the ceiling box to the black wire on the remote unit in the fan. Then wire the remote as shown on Tester101's diagram. Note that the ceiling wire go to the remote and the reomte wires go to the fan/light unit. Cap the red wire in the ceiling. Use the switch that has the black wire on both terminals and ignore the switch that has a red wire on one of the terminals (or remove it and cover the opening).
You're right, it's a new house that was pre-wired for fans with lights with separate wall switches. My wife bought 2 Hunter fans that came with fan/light remotes. Wiring the fans through the switches isn't a problem and that's how I have them now. Adding the Hunter remote receiver is where the directions aren't clear. They show the black, white and ground....I'm not sure how to connect the red switch wire form the 14/3 supply line to the receiver so both fan and light are remote controlled. What do I do with the red supply wire coming in? – R3A Jul 20 '15 at 18:56
Ideally, I want to leave both wall switches in the on position and control both the fan and light with the remote. – R3A Jul 20 '15 at 18:59
@R3A, you have to cap the red wire with a wire nut as it is not needed and cannot be used in the setup you have described. This will the switch that controls the red wire a "dummy", and the other switch will be the master on/off for everything. – mjohns Jul 20 '15 at 19:00
