I've had nothing but success with using Maestro dimmers on both LED and incandescent lighting for years, but recently picked up a new dimmer (MACL-153M-WH) and a pair of G7 Elko LEDs (30W total) and see a strange behavior from the dimmer.
Video to demonstrate: https://youtu.be/_fGK0vBbITU
You'll notice the light level should go to the second indicator from the top when I turn it on. I press the button, the indicator goes to the middle but the lights on the circuit do not turn on. Then a couple seconds later it's as though the dimmer resets, the indicator shoots up from the bottom again and the lights come up as originally expected.
The dimmer will be immediately responsive for a while once the lights have come up successfully, but if they sit off long enough the initial delay comes back.
I've tried adjusting the various settings (trim levels, on/off fade times) with no success and reset the dimmer back to factory.
I plan to try switching out the bulbs (never used G7 before) but the dimmer behavior is just generally confusing to me.
Update:
I bought another Maestro CL dimmer from a different location... same behavior.
Bought a pair of G7 Reno bulbs, same behavior.
Ran to Home Depot and picked up a pair Phillips slim style LED bulbs, and they work perfectly.
