How can I reduce the noise from an air handler unit?
I have a Goodman AR42-1 air handler unit in an open closet. The setup looks like this:
Air handler setup
When the air handler activates it sounds like this:
https://youtu.be/XTcLtrniQB8
Current sound levels:
Everything off:           36 dB
A/C on and inside closet: 63 dB
A/C on with door closed:  59 dB
A/C on in Living Room:    55 dB
Similar Questions
How do I reduce the noise from my forced air furnace? - recommends lining ducts with fiberglass
Is there any way to make my furnace quieter without replacing - recommends 1/2" rubber attached to the blower.
Home Soundproofing- recommends replacing a part of the duct with sound absorbing flexible duct or replacing a 6" section of the plenum with a rubber boot.
sound reduction in a condo HVAC closet - reduced fan speed, covered door except for vent with 1/2" of homastate.
  • It sounds like vibration noise, suck/blow noise and squeaky fan? For the vibration you could try a rubber matt under the assmbly, if the entrire wall vibrates not sure you can do much with out a major rework. The suck/blow. Does the lovred door being open closed make any difference to that noise... may be indicitive of not enough makeup air. Squeaky, oil it?
    – beast
    May 23, 2016 at 14:49
    Funny timing, I just moved out yesterday so I can't test any theories.
    – Joe
    May 24, 2016 at 20:29
  • 55dB is about the same as my dishwasher. Unless you're recording, odds are that if you gave it some time you'd brain yourself not to notice it. My boiler makes a bit of a thump when it ignites; seemed loud when I'd just moved in but I can't remember the last time I consciously noticed it.
    – keshlam
    Aug 20, 2023 at 12:54
I don't have air handlers, but I am into audio.
Air going thru pipes is like a speaker. It makes noise. Make sure everything is tight. It may sound crazy, but I put a 2 inch plastic pipe to my ear and "pin point " where the noise is coming from.
Once all that is done, wrap the pipes. Improves efficiency as well.
