I have a place that has a corrugated metal roof under a wood deck. It's a pretty large area, maybe 40' x 40'. When it rains, water leaks through some of the nails.
The deck boards are not nailed directly to the metal roof. The decking is attached to a frame built over the top of the roof. I'm guessing I need to remove all of the deck boards and patch the metal roof under the frame.
What would be the simplest way to stop the leaking?
