The windows in my basement are close to 12 inches tall, not going below ground level. There is a shallow window well made from old 2x4s framing a depression adjacent to the window. We have been getting heavy rain and I noticed that this window well is pooling with water. I am also experiencing regular flooding in the basement close to the same window well which seems it must be connected.
Do I need the window well if the window does not go below ground level? How do I avoid the water pooling in the window well?
I saw a video on YouTube where they put a drain in the bottom of the window well which drained into the sump pump. This is not an option as the sump pump and window well are on opposite sides of the house.
