We recently purchased a home and this window was boarded up on both sides. I removed the plywood to discover that it used to be a old coal chute. I removed all the old fiberglass insulation that was in there but I am at a loss on how to frame this to install a window. I know I need to finish removing the partially busted concrete on the left and right but I dont know how I would secure some pressure treated wood to frame the bottom.
Option 1 - tapcon screws (or similar) into the solid parts of the block.
Option 2 - stuff some wire mesh a few inches down the holes. Mix a very stiff mortar/concrete, place on top of the mesh, make a lovely smooth flat surface, and drop in some anchor bolts (probably overkill for a windowframe) or just screw the board in with tapcons or the like but without having to hit the webs since you'll now have solid masonry.
Option 2.5 (modern) - sprayfoam (great stuff or similar polyurethane foam) the holes, then put your concrete/mortar on top of the sprayfoam.
  • Thx for the prompt response. Makes perfect sense – Steve Salowitz Jul 7 '15 at 20:36
    Also make sure you use pressure-treated wood. – friedo Jul 7 '15 at 20:51
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
