I have a tube of bisphenol two part resin I'd like to use to repair headphones with a broken band. Problem is the band is plastic. Can I use a BPA resin to bond the earphone back to the band? I ask because both parts are plastic, and I don't know how well BPA plays with plastic. I also have JB weld which I know does NOT play well with many plastics.
I can also grab any relevant adhesive if there's something you think would work better.
