I just finished sheet rocking my living room and am stuck at a stand-still. My ceiling is 12' feet high at the tallest point and slopes down to 8'. That said, at the 12' wall, the sheetrock only goes up 8' and is then met by a lap and gap type wood, which then continues up to the ceiling. The wood then slopes (on the wall). At the 8' point of the ceiling, the sheetrock butts up to the ceiling.
My question is...How would I install a crown moulding or transition piece at the point where the sheetrock meets the wood? The previous owners had a painted 1x4 where the paneling (now sheetrock) met the wood. However, I am wanting something a bit nicer than just a 1x4 transition.
Either I am the only person out there with a room like this or I am searching incorrectly on Google. Does anyone have any ideas or pictures on this? I can definitely provide pictures if needed. I am tempted to pull the wood all the way to ceiling and continue the sheetrock all the way up. Any advice would be much appreciated!
