I tried to take down a shelf yesterday and water started coming from the wall. Called a plumber and discovered this in my building's water main:
Screw in building water pipe
The pipe is big enough and close enough to the drywall that it probably looks just like a stud to a stud finder or similar.
Is there any way I can install some kind of nail guard in front of the pipe or otherwise standard way I can indicate to the next guy to not drill in this location?
  • LOL, too bad it wasn't an electrical cable or the problem might have been "self-correcting". What you need to do is tear down all the walls in the house and install 1/4" hardened armor plate in front of all the water and electrical pipes. Jul 2, 2015 at 18:18
That screw seems to have found the magic spot and I think it's unlikely to happen again, however you might want to somehow strap a protection plate around the Tee; I wouldn't worry about the rest of the pipe.
  • There's a protection plate already every place the pipe goes through the stud. Jul 2, 2015 at 22:31
  • @BillyONeal By "the rest of the pipe", I meant the vertical run. AFAIK, there's no standard practice for protecting that. Good that it is otherwise, as it's required on stud penetrations.
    – Mazura
    Jul 2, 2015 at 22:51
