I have a generator with a briggs and stratton engine which kept dying on me. While trying to find out why, my neighbor helped me disassemble the carburetor. Finally, a week later a part arrived and I am trying to put everything back together. I tried my best to pay attention to what he did, but alas, I am only human and cannot recall where two parts came from. I even went and asked him and he cannot recall either.
I went through the parts manual and am 99% sure that one of the items (I believe the left one) is the shield-heat (#725) and one might be (kinda looks like) a piston assembly (#25), but super seriously doubt it as we did not mess with the pistons at all.
Both items have the same outside diameter, but one of them has a much wider inside diameter. One of them must connect two different fuel lines (assuming the one on the left which I assume is the shield-heat).
Can anyone identify these mystery pieces?
    The one on the right looks like a spacer that goes between the air cleaner and the engine. Do you have a long bolt?
    – Edwin
    Jun 28, 2015 at 3:20
  • @Edwin, you are a genius! You were exactly right. Could you please make that av answer so that I can accept it? Thanks!
    – KJ Price
    Jun 28, 2015 at 14:40
The one on the right looks like a spacer that goes between the air cleaner and the engine. A long bolt goes through the spacer.
