I'm trying to remove one of the sliding screen door wheels. It seems to one of those that is U shaped. I've looked at various videos and usually you can use a needle nose pliers and it'll come out. Funny thing is that there is a plastic piece inside that won't allow me to pull forward. It seems that I can only push in which will not remove it. Question is.... is there a way to remove the wheel correctly?
  • Is there a screw visible that may be an adjusting screw? It will be located on the upper narrow edge above the wheels. A picture always helps... – Jack Jun 27 '15 at 22:57
  • I took that adjusting screw out so you can slide the wheel part back and forth. It just won't come out. – Albert T. Wong Jun 28 '15 at 23:06
