I read a previous question regarding a GFCI outlet and a washing machine, but my issue is slightly different.
I have 2 GFCI outlets in a washroom in the downstairs of my home. One is obviously feeding power to the other, as well as an additional standard outlet (directly) above the washroom in my daughter's nursery.
I first noticed the problem, when I plugged a baby monitor camera in the upstairs standard outlet. The moment I plugged anything in to that outlet, the GFCI downstairs would trip.
This was the first time that GFCI had tripped since I bought the home 5 years ago. I changed the upstairs outlet, and it worked just fine, when I would plug something in.
"Daddy fixed it! He's obviously a master electrician!!"
Not so much.
Now, when we would run the washing machine prior to this whole charade, there was never any issue. I changed the upstairs outlet, and now (not every time, or at any particular point of a wash cycle) when we use the washing machine, it trips the GFCI outlet (the main, obviously).
    Have you replaced the GFCI receptacle itself? If it keeps tripping I would start there. It's most likely your receptacle, or the washing machine is leaking too much current to ground. It's much easier to start with replacing a receptacle than a washing machine – mjohns Jun 24 '15 at 13:55
  • Yes, I replaced the gfi receptacle as well. The main one, anyway, not the second one on the load side. Thebload side gfi is the only component out of the 3 that has not been replaced. I also plugged the washer into THAT gfi receptacle, to see if possibly that would make a difference, but it still tripped the main gfi. – Mike d Jun 24 '15 at 15:28
  • I JUST finished a load of clothes that tripped 3 times during the process. But there are times when we go a week without it tripping. We have a 7 month old, so we basically do at least one load a day.. – Mike d Jun 24 '15 at 15:30
    Are you saying you have a GFCI receptacle on the load side of another GFCI? – Tester101 Jun 24 '15 at 18:28
    What @Tester101 is getting at is that a GFCI protects everything that is served off the load terminals. All downstream receptacles are GFCI protected (and should be labeled as such--GFCI's usually come with little stickers in the box). There's just no point in wiring two GFCI receptacles in series, and there might be a possibility of nuisance trips with them wired up that way. It's different if you pigtail the wires and feed the GFCI's independently. Either way, don't label a downstream receptacle GFCI protected unless you've tested it to ensure that it really is wired up like you think. – Craig Jun 25 '15 at 4:28
