We've had unusually dry weather and our well has run so low that we had to call in a water hauling company to refill it a few days ago.
The water man told me that even though he dumped in ~ 1000 gallons, a great part of it will seep out of the well to the surrounding (drier) aquifer, the same way groundwater makes its way inside the well in normal conditions.
I'm thinking I could get some kind of drinking-water-safe plastic poly sheet sown or welded together at the seam to create a long and flexible tubing.
Then dropping the "sleeve" in the well with a heavy-ish "hoola-hoop"-shaped material the diameter of the well attached at the bottom of the sleeve end to weigh it down.
Wouldn't that effectively transform the well into a usable water reservoir?
Does this sound doable?
