I have an LG LBN10551PV apartment fridge. I ordered it with the door hinge on the wrong side (left) and would like to put it on the right. The instruction manual describes how to do this, and I've gotten to the final step, which is to attach the top hinge:
Then install the upper hinge (27) supplied in the refrigerator package placing the dowel into the appropriate upper hole in the door of the refrigeration compartment (A).
The top hinge plate clearly has a left and right hand version, and (short of flipping it over in the fourth dimension) there's no way of making it work on the other side. Here's what I have:
and here's what I need (the following is a dramatization):
(I had Sears deliver it and they didn't include extras from the packaging. I've checked through and behind all of the freezer drawers and all of the compartments within the fridge and there's nothing there.)
Both LG customer support and Sears Parts Direct are telling me that I can just use the existing top hinge, but I've tried everything I can think of to make it work and it just won't. Any suggestions on what to try next?
