Newbie painter here. Is it okay to throw rags and paper towels that soaked mineral spirits into a plastic bag and then into the trash can?
    You should leave them out in the sun away from your home to let the volatile components evaporate first. Commented Jun 22, 2015 at 2:26
  • The problem is, if I left the paper towels outdoors, they would blow away.
    – Kyle
    Commented Jun 22, 2015 at 2:41
  • Mineral spirits alone will not "spontaneously combust". Oils, particularly unsaturated oils like those found in oil-based wood stains and finishes, will. Let them dry out in a safe outdoor area before tossing, they won't blow away because you are smart and will place a brick or stone on them. Or put them in a metal can with a lid, away from combustibles. Commented Jun 22, 2015 at 4:25
  • It's best to make it a habit that anything containing oil, resin or solvent is a fire hazard either through fume ignition or spontaneous combustion. Shove it in a tin can away from combustion sources and combustible materials till it dries or polymerizes, if it's that windy weigh the thing down with a rock. I've seen epoxy heat to the point it smoked, the term is exothermic. As my grandfather's Ready Kilowatt sticker said, "Think safety, work safely". Commented Jun 22, 2015 at 5:26
  • I am actually using Klean Strip Odorless Mineral Spirits (which smell far from being odorless) and Minwax Helmsman Spar Urethane in this scenario. I'm not sure if the Urethane is oil-based, but I will dry everything out just to be sure.
    – Kyle
    Commented Jun 22, 2015 at 6:53
No it is not safe. The plastic bag will most likely make it worse. I have seen just an open pile of rags (not bagged) smoldering in a jobsite waste can at the end of a work day. I removed them and set the pile in the yard just to be safe, it was a pile of ashes in the morning.
9
  • Short of setting the paper towels on fire, how can I dispose of them?
    – Kyle
    Commented Jun 22, 2015 at 3:21
    @Kyle do you have an ash can? I bought a mini galvanized can (maybe 3 gallon) many years ago. It never rusts, and I can put hot coals and other flammable things in it without worrying about setting my grass (or house) on fire.
    – user4302
    Commented Jun 22, 2015 at 3:34
    What I do in these cases when I am staining with oil based products, I open the rags, drape them over the edge of my trash can, single layer, and other places if I don't care if the stain, or in your case, paint, doesn't matter if it gets around. Let them dry, then dispose of them.
    – Jack
    Commented Jun 22, 2015 at 4:06
  • I don't have an ash can @Snowman but maybe now's the time to buy one
    – Kyle
    Commented Jun 22, 2015 at 6:49
  • So just to be clear, as long as they are dried @Jack, the towels/rags are good to go in the trash then?
    – Kyle
