Currently my main level subfloor is joist, 1/2" plywood, then 3/4" partical board. I am in the process of replacing the partical board with 3/4" with Oriented Strand Board Tongue and Groove.
After ripping up the partical board - Should I glue & screw the OSB board down? Or just screw with red rosin paper in between?
Note: when the subfloor is complete I'll be laying builders felt paper down prior to installing 3/4" solid oak hardwood.
  • Others may not agree, but I would not hesitate to set the oak floor directly on the 1/2" plywood. If the subfloor was a little thicker, like 5/8" would have been better. Use the proper paper, not rosin paper, it holds water not block it. There is a tar paper out there that is thinner than 15 lb felt, it may be 5 lb or perhaps 10 lb felt. All the floor installers I seen use it. FWIW, the 1/2" plywood used years ago is a much better quality than todays plywood.
    – Jack
    Jun 16, 2015 at 16:16
  • I plan to use tar paper in between the hardwood and OSB. Are you also saying 5 lb tar paper in between the plywood and OSB? Jun 16, 2015 at 17:18
  • Actually, 5lb paper over the 1/2" subfloor before the 3/4" oak goes down.
    – Jack
    Jun 16, 2015 at 19:47
If you truly want to add another layer of subfloor to the existing layer, you will only need to add another layer of 3/8" plywood, or OSB, (I am not a big fan of OSB) glued and screwed. THEN add the 5 lb. flooring paper, and your oak flooring. Otherwise I would go directly over the existing 1/2" subfloor with the flooring paper and oak floor. I suggest the lightweight tarpaper because it reduces moisture from rising into the floor from below, as in a crawl space. Red rosin paper, which I have used also for under wood floors but will no longer, holds moisture. It has been used under many floors over the years, I have demo'ed many floors that had it in place.
My reason for the littlest possible rise in the floor is it affects stairs, which become a safety issue, doors need to be cut, and other things that need to be cut or adjusted from the additional height all the layers produce.
    Then you will still be adding another 3/4" in oak floor? If you do still go over the existing with the 3/4" OSB, I would not glue it, only screws. Later work to do would be made difficult
    – Jack
    Jun 17, 2015 at 16:15
