I'm trying to build a TV stand which will have a top on it about 80" x 20" x 3/4". It can be thicker than 3/4" but I'd like it to be at least that. Assuming I build a supportive frame, what's the cheapest way to get a piece that fits the bill? I've looked at using plywood and edging as well as biscuit joining planks together, but would like to hear other ideas.
Depends on how finished you want it to look. For a very rough table, you don't even need to join the tabletop planks - think of it the same as building a mini deck. – mbeckish Jun 9 '15 at 19:21
Edging can be thicker than the actual to, and often is, both to give the appearance of a thicker top and to improve its rigidity. – keshlam Jun 9 '15 at 19:55
Add a comment
A narrow slab door might fit the bill. 80" is a very common height. Architectural recycling places, such as Habitat For Humanity Restores (if you're in North America) have them for nearly nothing. If you get a hollow core and it's too wide, be aware that it's a bit fiddly to make it work well.
I really like this idea. We just got a HfH Restore nearby and frequent it often! I assume a solid core door I could rip to the appropriate width right? – Chuck Claunch Jun 10 '15 at 4:00
Note that "solid" doors are solid (not hollow) but not not actually solid wood. If you rip a solid door to width you may expose particleboard filler. – Hank Jun 10 '15 at 4:35
1You'd probably expose particle core, but you could either put that to the back or edge it with some thin veneer. – Aloysius Defenestrate Jun 10 '15 at 13:55
