How do I debug/diagnose/fix my swamp cooler fan, that won't turn on seemingly? The pump runs OK but the motor, nothing.
OK first thing I did was remove the motor and try it in a different unit. It worked OK. So the motor's not the culprit. Another option would be to use a volt meter on the plug where it plugs in (turn the fan switch on first, check for A/C between basically all pins) see if it's passing current up there or not. If yes, motor or connection to motor would be suspect.
Next thing was to test if the electric circuit breaker was working (either using a volt meter, or by swapping it with another one). It was.
Next would have been to test the connections at the thermostat to see if they were "live" and if the thermostat, turned on, was sending "live" out up to the swamp cooler on the low or high wire.
But didn't have to, found my actual problem was that I was turning the fan to "low" but not adjusting the thermostat, which was still set to "very hot" so once I switched that, it all worked. Go figure.
lol! d'oh! Sounds like you've got a thermostat like I haven't seen before. Both of my swamp cooler thermostats use temparature numbers, instead of words like "very hot". Question: does your thermostat have an indicator light on it that lights up when the cooler is supposed to be running? – Aaron Wallentine Aug 3 '16 at 20:18
@AaronWallentine that one didn't it's an older style with "just a dial" and a rocker switch for the fan. – rogerdpack Aug 3 '16 at 22:00
1oh ok ... yeah, in that case, it's hard to tell if it's "supposed to be on", i.e., if the switch is on, without some other indicator. : ) – Aaron Wallentine Aug 3 '16 at 22:59
