I purchased and installed a set of sliding mirror doors 2 weeks ago. In the space of two weeks all four of the doors have developed cracks in them. A couple of them are at least a foot long.
I have not been abusing them excessively. The one crack I was aware of causing was when I did open a door a little bit too hard and it caused it to knock into the adjacent door. Surely the doors should be built to withstand a little bit of a knock.
I can think of two possibilities - either I have installed thew in such an incorrect way that means they are incredibly fragile, or the doors are of very poor build quality. I did follow the instructions to the letter.
Before ranting at the manufacturer - is it possible that I have just missed something obvious when installing that could have caused them to crack so easily?
Edit
I forgot to add a conclusion. I contacted the manufacturers and they said they had never seen their doors crack so easily before. Without any argument they replaced the doors straight away. The replacements are still going strong without a crack > 6 months later.
