I purchased this Techni Mobili L-shaped tempered glass desk up. The manual says each glass piece can hold 80lbs. My computer weighs in at 50.6lbs and is currently resting on the corner edge of the glass right above a support beam + glass circular support thing. The glass bows only .5cm down. What I'm worried about is, since the computer is resting right on the edge, will the 80lbs rule apply and am I risking my expensive machine? Thanks
8mm thick 21 inches length 41 1/2 inches width
http://www.rtaproducts.com/_uploads/instruction-manuals/3803.pdf
