I tore out my front porch slab so I can waterproof the foundation. It was also sinking and since it has a column to support an overhang, that's a problem. My question is what should I do about where it needs to come up to a level higher than the bottom of the vinyl siding? In an ideal world, the slab for the porch would be against the block foundation of the house, staying well below the siding. The level of the slab also puts it above the wooden bottom plate of the house. In the picture you can see by the dark line on the siding where the main level of the slab was (there is also a step up to the front door). It also looks like no forms were used by the house, the concrete was just poured against the siding. How would I do better? enter image description here
  • Wow, just wow - what a throughly poor job that was. Don't repeat it.
    May 26, 2015 at 3:00
  • And that's not all I've encountered at this house. A deck ledger was put right over vinyl siding. No flashing at all. And then to top it off they used long nails for the joist handers that also penetrated the siding!
    – BrianK
    May 26, 2015 at 3:29
You can pour a new slab up to the level of the foundation, not higher. In this case, you could basically fabricate a new concrete patio that's below the level of the previous one and build some steps leading down from the door to the patio.
You could also forget about making a concrete patio and build a wooden (or composite decking) patio at the current level of the door.
In general, I would recommend against pouring concrete right up against the foundation, because it provides hidden termite entry points and makes it very difficult for you or future owners to insulate the exterior of the foundation later (if this is an appropriate foundation insulation and hasn't already been done). Also, you have to get the slope away from the house perfect or else you're redirecting water into your foundation.
  • Interesting idea about a wood deck. The lower level might work, as there was already a small slab in front of the porch at the lower level.
    – BrianK
    May 26, 2015 at 3:33
  • I think a wood deck is probably the way to go, just make sure that the land is sloped away from the house. It's possible that by excavating all this concrete you have created a low point in this corner, which is bad for water runoff. Also, this is a good time to install a perimeter drain if drainage is questionable.
    – Hank
    May 26, 2015 at 23:43
  • Yes, installing foundation waterproofing and a perimeter drain are the main reasons for tearing out the slab.
    – BrianK
    Jun 2, 2015 at 3:33
