I have a 12" x 24" piece of plywood that is 1/4" thick and I'd like to hang it on the wall. I don't want to frame the piece or put any nails in it. Here are a couple of ideas I had:
- I was hoping there would be some mounting/hanging brackets similar to what picture frames use but haven't had any luck for 1/4". Also, I know plywood isn't very resilient and I'm not sure if screwing in to it will crack the wood.
- Another option is attaching string to the piece and then hanging it from a nail in the wall but not sure what the best way to permanently attach the string to the plywood is.
- I would be fine drilling small holes in to the wood for string/wore to go through but I don't have an automatic drill with me and, again, I worry about cracking.
Any ideas out there on ways to best hang a 1/4" piece of plywood?? I'm open to any suggestions.
Any help would be appreciated. Thanks!
