I want to install a series of floating shelves to hold mostly books and some other heavy items in my living room.
I found this on Instructables where one use expansion bolt and 6mm thread bar for what seems like a very solid setup. I was wondering if the expansion bolt could be used in the wall studs as my walls are way too thin oterwise.
I also found this post here where one recommend to use Z-clip. Yet I am not sure how much weight a 12 inch deep shelve could hold which such a mount. How can I mount heavy stuff on wooden studs?
What do you think is the most robust choice?
