I had to patch a cat door that was cut into the drywall, and put in a cutout that left small gaps around the perimeter. When I applied the first coat of joint compound, it pulled into the gap in certain places, so I have to apply a second coat. Do I or should I wet the first coat before applying the second?
No. You shouldn't have to wet the first coat.
  • 4
    Rather the opposite - be sure the first coat is fully dry before applying the next one. "Mud" (joint compound) is not mortar.
    Commented May 13, 2015 at 2:09
