I'm trying to figure out a possible way to eat through concrete without damage pex tubing inside (its a radiant heated slab). Is there any way using some type of acid (hydrofluoric, muriatic ) to eat a 4" wide and 4" deep channel through the slab that could be tapped out with a blunt chisel? Pex tubing is resistant to most acids so wouldn't be damaged.
Secondly would this be cost effective (under $1000), I need this channel to be about 71 feet long.
