We are having a fairly large built-in bookshelf (w cabinets in bottom) made for our livingroom and the guy making it recently mentioned that he was considering mdf for the back panel (the rest of the bookshelf is plywood). Is mdf ok if it is just the backing? The is going to be a 90 inch wide unit, 8ft tall. We hope to have this stay strong and in good condition for many years. Just trying to understand if this is a bad place to use cheaper materials or if it is ok? Also, the 90" unit is made up of three columns of 30" wide shelves. We had imagined that he would have constructed 3 different segments -basically three different bookcases of 30" each and then attached them together. But instead he has started it as one huge unit - a 90" board all the way across the top and bottom. (One unit for the top and one unit for the run of bottom cabinets.) He is adding vertical plywood panels going down at 30" intervals inside the 90" frame/box that he has made. Aside from my confusion about how he will attach fixed shelving at the same height throughout the unit, I am also wondering if the unit will be much weaker and less stable if it is made as one 90" piece versus three separate smaller units attached. I kniw he's done other carpentry projects but I don't think he's ever done something like this before so I'd like confirmation that this all sounds ok (and advice on mdf backing). Thanks!!!!
  • You should never use mdf when making shelves, for anything. There are just too many other alternatives that make more sense.
    – DMoore
    Commented May 8, 2015 at 12:59
    @DMoore - the back is not a shelf.
    Commented May 8, 2015 at 13:26
    For backing it's only to help keep the shelf square through the years. The stress on it is pretty minimal. Some guys build kitchen cabinets with 1/4" backing which is pretty small and then buffer with a 1/2" piece to fasten to the wall.
    – Dano0430
    Commented May 8, 2015 at 15:35
  • A big difference between good craftsmanship and shoddy work is the choice of materials. MDF, especially thin sheets of it, doesn't hold fasteners well at all. The first time a book slams into the backing, it will pull it out and you'll see a gap between the frame of the shelf and the backing sheet. Quality builders will use 1/4" or 5.2mm plywood with 3-plies and at least one stain-grade face.
    – William S.
    Commented May 9, 2015 at 6:29
First off, please clarify your questions in a list, it'll help sorting through your narration! Anyway, I'll take a stab at what I think your questions are:
  1. MDF for backing: MDF's weak point in this installation would be in its tendency to sag when supporting weight if it were to be used as shelving. As a backing it is perfectly suitable, provided it's joined properly (using pilot holes, the right screws, etc.).
  2. are 30" segments ok vs. individual 30" carcasses? Tough to say without knowing anything about the joinery. I'm not sure why you question the ability to maintain consistent shelf height though - that's the easy part (just cut the "wall" segments to the same dimensions.
In general, built-ins are a low-risk proposition - woodworking joinery is really meant to maintain joints subject to complex and changing loads (imagine rocking on the back two legs of a 4-legged chair). The static loads associated with built in shelves (vs a movable bookcase), even large ones from many books, are less of a concern. Actually, my main concern with this is your friend's design of the shelves to minimize sagging - make sure he has taken that into account. A helpful tool for that is: http://www.woodbin.com/calcs/sagulator.htm
    One potential problem with a huge built-in is that it can be impossible to get into place - it might fit there, but if it's built elsewhere and transported to the house, you may find that it's impossible to get it into the room it goes into. If built in place you sneak past that one.
    Commented May 8, 2015 at 13:30
The MDF for backing ONLY will work fine. The 3 segments for the sake of getting in the house is not only a good idea for handling, but will make it possible for getting through your doors. It helps save the walls too. Small or large, a back on the cabinets will stabilize the carcasses (body of the cabinets). Once set in place, fastened together, and fastened to the walls (you did say built ins?) They will be stable and strong, strong as long as the joinery holds up. The backer, after securing it together and to the wall, will have little to do with the strength. It works best while transporting, and keeps it square while installing, for the most part.
