10
I have a colonial built in 1913 and I live in NYS. My roof was just completed today and I have exposed nails across the entire roof!
image of roof nails
It was not like this before. When I asked the contractor about it, he said this is normal, but I'm having a difficult time accepting this answer. I have included a picture to show what the entire roof looks like from the inside of the attic.
  • My house in Florida has very long nails too. They say it's preferred for hurricanes. I even got a discount on insurance. (just thought I would share even seeing you don't live in Florida)
    – RichardW11
    Jan 14 '21 at 13:51
  • @RichardW11 your insurance policy specifies roof nail length???
    – jay613
    Jun 19 '21 at 22:38
    @jay613 not sure... I know when I bought the house and made a comment, they said it's a part of the wind mitigation Florida insurance companies' discount.
    – RichardW11
    Jun 20 '21 at 16:45
17
That's perfectly normal. I would have preferred to see the vertical joints in the sheathing line up with the rafters, but that's about it. Roofing nails actually should come through about a quarter inch - I'd be more concerned if they didn't.
9
  • It looks like a majority of the nails are coming through 3-4". Is that also normal? May 8 '15 at 12:49
    @DarrickHerwehe - The nails coming through 3-4" are for the sheathing (thus I would have preferred them going into rafters). It certainly won't harm anything unless as Tyler Durden mentioned, you stand up suddenly.
    – Comintern
    May 8 '15 at 12:53
    It is better to have too much nail than not enough.
    – DMoore
    May 8 '15 at 12:57
    It would be difficult at best to hit every rafter while roofing. It's possible they used longer nails because they needed them at one point in the project and rather than worry about where to change the nails they just used them for the whole project. As stated there's nothing wrong with the nail poking through a bit extra.
    – Dano0430
    May 8 '15 at 15:18
  • This roof was originally wood shingled over spaced furring strips. They've laid OSB sheeting on top to handle standard asphalt shingles. The nails you show are probably 10 penny, driven through to attach the sheeting to the spaced furring strips that wood shingles are normally attached to. The rafter is that thick piece of wood to the right of the picture that the furring strips are laid across.. Jun 18 '16 at 6:17
Most sheathing now is 1/2 to 3/4 at most and a shingle is only about an 1/8 so with that being said the distance with synthetic is about an inch. If you're using a nail gun, which most roofers do, then your coils are 1-1/4 inch long at a low end (they don’t make smaller). So, unless you're hand nailing, yes there will be about 1/4 inch showing. It is normal for this to happen; it is unlikely for there to be no nails showing unless your roof is made of planks, in which case they won’t show.
Looks to me like someone was too lazy to go to the hardware store to get proper length nails or the hardware store was out of the desired size or they didn't want to pay the price for a full box of roofing nails...or buy a full box of roofing nails...and the nail gun was broken. This length and type of nail used is just wrong on multiple levels. They just used whatever they had on hand.
  • Most of the nails we're seeing aren't even roofing nails. The vertically grouped nails on either side of the OSB joint are actually framing nails holding the OSB sheathing down to the original skip-sheathing that was, I'm sure, applied to the house when it was built in 1913. The nails, in horizontal rows, sticking through about 1/4" are the roofing nails, and they seem to be just about perfectly sized.
    Jan 14 '21 at 12:25
  • With that much experience you should know that roofing nails are required to extend through the sheathing in many cases.
    May 17 '21 at 21:10
  • @isherwood, if you read my comment carefully I did say TYPE of nail
    – DAS
    Jun 19 '21 at 21:38
I think there is a big problem with nails extending through the sheathing into the attic space. When the temperature falls below 32 degrees the humidity in the air will condense on the nails (frost). Above 32 degrees, the frost melts and water soaks back up into the wood (capillary action) and over a few winters you will have a moist wood surface - and a mold problem. That is the cause of my problem, I think. I know proper attic ventilation - air flow - is suppose to eliminate humidity but humidity is in all the outside air. The humidity is increased by improper ventilation from bathrooms etc, but air flow does not eliminate or reduce humidity in the air. Temps around 32 and humidity around 70 to 90 will result in frost and water and mold. Nails extending through the sheathing seem to be source of a serious problem in my attic. Other opinions most welcome.
  • 4
    Although your idea sounds logical it is quite normal for nails to protrude.
    Dec 19 '16 at 14:05
  • It does sound logical but if this was really a big problem, someone what have invented an anti-nail-tip-condensation contraption and hired lobbyists to make it code-mandatory everywhere.
    – jay613
    Jun 19 '21 at 22:37
-2
Once you fully nail through the roofing wood to the other side you end up with a stress fracture for moisture from both sides.nails should nit reach the full thickness to the floor roofing material and if its a new home structure as it makes the electricians and heating /cooling people work slower at times too.
-3
This is not normal nor correct. It is common because most people who install roofing systems have no idea what they are doing. The roof deck should be 1 inch or thicker ply wood and the nail should be 3/4 inch nails, with 3/8th inch heads, galvanized and coated. When the nails are driven too deep, they supply a water channel which causes mold to grow on the roof and eventually destroy the whole house. Once the house is infested with mold, you will have to burn it down just to get rid of the mold. That mold could kill your family. Eventually the mold will show outside on the roof and grow under the areas where the nails are penetrating the roof deck. The reason this nail penetration is common is to save the labor of changing the nail pack in the nail gun, and the extra cost of using real roofing nails. It only saves about 100 dollars / house. Some contractors also substitute particle board for plywood which grows mold even faster. Google images for mold on roof.
This is a copy of the code that is about the same in all 50 states. The code states that the nails only penetrate when the roof deck thickness is below 3/4 of an inch. To hold snow, ice, and withstand wind, it has to be at least one inch thick plywood. So if you can see the nail heads and the right nails were used, the roof is too cheap to last anyway. The correct way to do this is with 1 inch or thicker ply wood for the roof deck/sheeting, and 3/4 inch galvanized nails with 3/8th inch heads. Also, the building codes are ridiculously outdated. They should not allow the roof sheeting/decking to be less than one inch or less than 3/4 inches when made of wood, especially in areas with snow.
https://up.codes/viewer/north_carolina/irc-2009/chapter/9/roof-assemblies#R905.2.5
R905.2.5 Fasteners
Fasteners for asphalt shingles shall be galvanized steel, stainless steel, aluminum or copper roofing nails, minimum 12 gage [0.105 inch (3 mm)] shank with a minimum 3/8-inch (10 mm) diameter head, ASTM F 1667, of a length to penetrate through the roofing materials and a minimum of 3/4 inch (19 mm) into the roof sheathing. Where the roof sheathing is less than 3/4 inch (19 mm) thick, the fasteners shall penetrate through the sheathing. Fasteners shall comply with ASTM F 1667.
  • While a 1" plywood roof sheathing would be nice (if the roof is built to support it), I'd like to see a code reference that requires it as you imply. I would agree that the nails in the OP's post do not look like they are properly galvanized roofing nails, nailing through the sheathing is pretty common. Also, got a reference for "burn it down" once you've got some mold in the roof? That seems pretty dog-gone extreme, considering there are a number of common household chemicals that will easily & safely kill mold...
    Jan 13 '21 at 19:04
  • Mold contributes to over 400,000 respiratory illness deaths / year. I would like to know if you would risk the lives of your family on a cheap roof that could be done right. I don't see the lives of my family as trivial and the 1" roof decking should be a minimum standard to protect families. There is nothing that can completely remove mold from wood once it is infected. As far as supporting weight, the roof must support the weight of the roof and a calculated amount of snow, rain and wind force. If it won't hold 1" plywood, it probably won't meet the other standards either. Jan 13 '21 at 19:09
  • You say, "1" roof decking should be a minimum standard" - is that your opinion or is that in the IBC somewhere? Also, yes, I put a roof on my garage nearly 30 years ago, I live in the very rainy mid-west US, and no, I've never had a bit of mold growing on the underside of the roof, so I'm quite comfortable with the arrangement. Again, I ask for code references for your assertions, not opinions. That is the way here at the StackExchange sites. If you'd care to take the tour, you'll see what's expected of in an answer here.
    Jan 13 '21 at 19:14
    Also, please edit your new answer into this existing one. While writing up 2 answers is acceptable here, these two really need to be combined.
    Jan 13 '21 at 19:19
    This just isn't correct. Shorter nails would still provide a water channel into the wood itself, instead of just through it -- but the nails shouldn't be getting hit with much water anyway based on the way the shingles are laid on top of them. And having nails go all the way through is common and I've never heard of it causing mold unless there was also something else wrong.
    – Nate S.
    Jan 13 '21 at 19:21
-4
Nails should never go through the plywood, water does go under the shingles and rust the nail thus making it thinner, more water to go through, the correct nail length should be the sum of the shingle thickness plus the underlying materials minus 1/4 inch...it is strange that protruding nails are thought to be normal! it is a common error in American building construction methods...you will not find this elsewhere in the world!
