Here is the valve that need to be unscrewed: Here is the valve that need to be unscrew
the lighter:
the lighter
I have seen some expensive solution, and I'm not even sure they would fit since those valve and removal tool might not be standard.
I have tried with 2 small slotted screwdrivers, but without success.
Any idea?
(A low quality gas that contain impurity blocked the valve)
  • Not sure I see how this fits in with do-it-yourself home improvement?
    – Tester101
    May 7, 2015 at 10:40
    Despite the name, diy is specifically a home repair/improvement discussion area. unless you are living in that lighter, this is off topic.
    – keshlam
    May 7, 2015 at 18:44
Go to basement, garage sale, or thrift store and pick up an old, regular screwdriver about the right size to fit the slot in the lighter. Use a file, hacksaw, angle grinder or mototool type device to cut a slot in the screwdriver. Make the slot big enough to fit around the gas nipple. Unscrew as needed.
