I'm making some pull up bars with 1 1/8" diameter holes and have some questions about how I should drill the holes:
Right now I'm planning on using spade bits. A drill press is not practical in this situation, but I could use one if I had to. The poles are 6" x 6" x 10', and a small imperfection will span across 5' to magnify. Any suggestions on some sort of portable drill press I could clamp onto the wood to use?
Is there a better tool for this job? Ideally it should be inexpensive/rentable.
