We had an issue with the hot water heater in our basement that resulted in some minor flooding. Fortunately most of the water went straight out the nearby garage thats across the hallway, but some soaked into carpet in rooms on either side of where the water heater was. No furniture was touched and the baseboards don't look particularly damp either. The water level was not ever higher than an inch since I got to the shut off valve pretty quickly.
At this point I've taken up the carpet and removed all of the wet padding and placed it outside. This was less than a 6'x 14' rectangle of padding. I have a single consumer grade dehumidifier running, and our AC fan on. The RH has never read above 56%. I have the carpet drying, backing up. I have not removed it completely as it is wall to wall only a small portion go wet, less than the 6' x 14' square of pad I removed.
Is this enough to prevent mold given the relatively minor damage or should I be taking additional steps.
