In several places in the ceiling of my 1986-built bungalow, there are long straight cracks running along the ceiling.
First image
Second image
  • What's causing them?
  • Should I be concerned?
  • How can I stop it from increasing?
  • How can I repair the damage already done?
Thanks
The building settling.
Not really.
You can't, but improper climate control (swings in temperature and humidity levels throughout the house) will make it worse.
I'd use fiberglass tape and joint compound (chemically setting plaster; not water soluble top coat). The non-textured ceiling would be easy. The textured one needs to be repaired in the same way and then re-textured or the entire ceiling completely de-textured with a skim coat.
I'm guessing it was originally textured with a textured roller.
Another option is to caulk and paint it every time it redevelops. It's definitely worth a shot at this easy method, to see how long you can get away with just a coat of paint. You might want to widen the crack (with a painter's tool; a 5in1) so that it fills with paint/caulk and doesn't just make a bridge over the gap (that would crack again guaranteed, very soon).
  • I'm looking up at a similar crack right now; I've been trying to decide whether to just fix it or put in a coffered ceiling. – keshlam Apr 29 '15 at 23:04
  • @keshlam I've used decorative purlins on long cracks that just wouldn't give up. Trim for the win! – Mazura Apr 30 '15 at 3:31
