My experience is that black out blinds always let a little bit of light in round the sides. What do other people recommend as a solution to this?
  • I've posted another question, related to this. You may want to check it out if you're still looking at solving this.
    – Kieran
    Jan 21 '21 at 22:34
I have a bit of a botched solution for this that I use in one of our bedrooms. The curtain has a blackout lining but sits about 8cm away from the wall. Light bounces off the lining, onto the wall and into the room.
I made a strip of black plastic by taping together pieces, the strip is about 5 metres long. I drape the strip over the curtain rail brackets such that the sides hang down and block the gap around the sides of the curtains. This eliminates about 90% of the residual light.
I'll add a photo later, since my description is probably not very good.
