I was trying to clean my shower drain with a toilet brush and the toilet brush broke inside the pipe. Now, the head of the toilet brush is stuck about 2 feet down in the pipe. Water will not pass, the head is stuck.
Any suggestions on how to pull this toilet brush head out? I was thinking a toilet snake, but not sure it will even get past the brush head to pull it out from the underneath.
  • It might be time to call a plumber. If you have a snake, why were you using a toilet brush?
    – Comintern
    Apr 20, 2015 at 3:06
  • @Comintern I don't have a snake. I was thinking about going to buy one to try and get the brush head out. How would a plumber go about this? Anything I could try doing, anything at all?
    – user5826
    Apr 20, 2015 at 3:10
    My guess is that they'll have to run a snake down to it and try to get the spring tip or hook tangled with the head of the toilet brush enough that it will stay together long enough to pull it out. Depending on the run of the pipe, you might be able to fish at it with a coat hanger with a hook bent onto the end.
    – Comintern
    Apr 20, 2015 at 3:17
  • Is the shower drain pipe enclosed in a floor, or can you access it from underneath (e.g. from a basement). Hopefully it won't be necessary to cut the pipe. Cutting/replacing the pipe itself would be easy enough, but access to the pipe could be destructive. Apr 20, 2015 at 10:55
    Called Roto Rooter. Plumber used a long drill to break the brush head in half, then used long pliers to grab each piece and pull it out. $450 big ones!
    – user5826
    Apr 20, 2015 at 19:54
Coathanger, cut into a wire, with a hook on the end might work. Push the hooked end past the stuck brush, keeping the hook near the perimiter of the pipe. Rotate the hanger 90° so the hook is under, and engages, the stuck toilet brush. Pull up on the end of the coathanger with a pliers or vicegrips.
If it's the type that's plastic use a long drill bit but slide a metal close hanger with a hooked end down its side first to hold it in place , know with your drill gently drill out the center to make a hole all the way thought so you can use your close hanger to to slide down the center and hook it. Once you have done this boil water get it very hot this will soften the brushes so it can slide out. If your close hang doesn't pull it up get a long needle nose pliers and grab it but boiling hot water is the trick to soften the brushes to get it out
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know the details of contributing here. Aug 14, 2020 at 12:36
